enable snmp traps identity-management
Description
Enables the identity management feature to send SNMP traps for low memory conditions.
Syntax Description
Default
No traps are sent.
Usage Guidelines
The low memory conditions are described in the description for the configure identity-management stale-entry aging-time seconds command.
The following command enables the identity management SNMP trap feature:
This command was first available in ExtremeXOS 12.4.
Platform Availability
